Reason why this vlan is using secondary instead of primary Nexus 9300?
MicJameson1
Hello.
Please see below 2 outputs.
In the two Nexus 9300's-- note that the secondary device is the Active device for Vlan 81. I expect this is not intended, but maybe it is because the priority is not 110 but 90.
Vlan 81 is a management vlan.
QUESTIONS:
1. All things being equal, would you expect this is currently active status is not intended, or do you expect this is probably set because of some load balancing strategy?
2. What is the correct way (and command(s)) to set vlan 81 to be routing through the (primary) "Nexus9300-1"?
Thank you.
(obfuscated)
Nexus9300-1# sh hsrp br
Interface   Grp    Prio      P    State              Active addr                Standby addr               Group addr
Vlan20      200    110     P    Active               local                       172.16.170.126         172.16.170.1 (conf)
Vlan80       10     110     P    Active               local                       172.16.220.3             172.16.220.1 (conf)
Vlan81       11       90       P    Standby         172.16.221.3                   local                    172.16.221.1 (conf)
Nexus9300-2# sh hsrp br
Vlan20     200     90     P    Standby         172.16.170.125                  local                   172.16.170.1 (conf)
Vlan80     10       90     P    Standby         172.16.220.2                      local                   172.16.220.1 (conf)
Vlan81     11       110     P     Active                   local                             172.16.221.2           172.16.221.1 (conf)
Yes. If you dont config any priority both will  use the default which is 100 and they will use the highest IP address  for tye break and elect the Active
8 Replies 8
@MicJameson1
 Yes, the higher priority becomes the Active. Nexus-2 is the activie due the higher priority
Does this priority only change from a user's explicit configuration?
To make the first device you can raise the priority of the primary device under the HSRP configuration. Or you can lower the priority on the secondary HSRP device. You will also have to make sure premption is enabled on both HSRP instances.
-David
Friend' this NSK not any router or SW'
Both SW is active and forward data no matter which one is active or standby.
The only difference is active in NSK only reply to arp for VIP of HSRP that all.
So change or not change priority not effect so much.
I DONT KNOW WHY OTHER MENTION IT EFFECT.
I didn't know that! Thanks for the helpful article.
You are so welcome @David Ruess
Have a nice summer
MHM
