Recommendation for router to replace Cisco 837
harry.dass
We are presently using a Cisco 837 unit to connect up to the Internet using Singtel's bizlink service. We have a new requirement to segment our office LAN into 4 subnets.
We are also planning to introduce VPN services for our laptop users.
Please recommend us a model that will satisfy the above requirement.
mheusinger
Level 10
Level 10
the Cisco 850 Series and 1800 Series allows VLAN configuration and IPSec tunnels. Have a look at f.e. "Cisco 850 Series and Cisco 870 Series Access Routers Software Configuration Guide"
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a008045d273.html
"Cisco 1800 Series Integrated Services Routers (Fixed) Software Configuration Guide"
http://www.cisco.com/en/US/products/ps5853/products_configuration_guide_chapter09186a008045827f.html
You would then need additionally a LAN switch, which is dot1q capable, like the Catalyst 2950.
Hope this helps! Please rate all posts.
Regards, Martin
thanks martin, ill look through those guides and get back if i have any furthur questions :)
