interface Po1
jinkazama_2
Level 2
Level 2
When I configure etherchannel, using channel-group 1 for example, the int is references as Po1 ... why is this? what does Po1 stand for?
farkascsgy
Level 8
Level 8
PO1 is the etherchannel interface - Port channel interface. You can use Po1 interface as Layer 2 or Layer 3 interface incase of L3 you can assign IP to Po1 interface. Po interface represnts the channel, the grouped interfaces...
bye
FCS
Please rate me if I helped.
gpulos
Level 11
Level 11
when you use the ChannelGroup command to assign an interface to a etherchannel group, IOS will create the 'Po' interface, if it does not already exist, which is the portChannel interface.
as previously stated this can be used at L2 or L3.
please see the following link for more portChannel info:
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_guide_chapter09186a00800f0e21.html#wp1025372
