recovering a 2950 using xmodem
rmmbminola
hello i was in the middle of upgrading flash on my 2950 and the power went out so i now have a switch without flash in switch: mode tryed to do an xmodem up download but it starts get a few CCCCC then get I/O error any help please.
tried it several times same result.
thanks for your suggestions.
kerek
Level 4
Level 4
Try to use tftpdnld from rommon.
Here is link:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
Although this link describe, how to recover 2600 series I think you can use it with 2950 too.
Hope it helps, rate if does
Krisztian
i need to use xmodem according to cisco but it starts and after 6 CCCCCC it gives me the I/O error, thanks still tring.
hello again looking at switch: dir i get
flash[0]read/write
xmodem[1] read only
null [2] read/write
bs[3] read/write
tring to download new flash to 2950 but when it starts unisng xmodem it start with CCCCCCCCC then i get I/O error same place every time any help would be great please, i am using it to study for my CCNA was tring to upgrade the ios so that i could practice the config vlans with the config t instead of using vlan database command
p.s sorry to be such a pain in the you know what.
thanks again for your replies
