RED/WRED
sarahr202
Level 5
Level 5
Hi everybody.
RED/WRED randomly pick packets and dropped when the threshold are reached. My question is : Is it  always a TCP packet or it could any packet?
Reza Sharifi
Hi Sarah,
So, apparently RED and WRED is more effective with TCP connections according to this document;
WRED is useful with adaptive traffic such as TCP/IP. With TCP, dropped packets indicate congestion, so the packet source will reduce its transmission rate. With other protocols, packet sources may not respond or may resend dropped packets at the same rate. Thus, dropping packets does not decrease congestion.
here is the link:
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfwred_ps1835_TSD_Products_Configuration_Guide_Chapter.html
Reza
Reza Sharifi
Hi Sarah,
here is the link:
Reza
Thanks reza, i understand how red or Wred affect tcp traffic, however i am trying to find if wred or red pick tcp only or any traffic,
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
It depends on what traffic you're subjecting to WRED.  I.e. WRED doesn't, by itself, examine "kind" of packet.
For example, WRED will often, by default, apply different min/max limits depending on a packet's ToS.
