redistribure route between vrf ?
rico_hao40
I am new in configuring vrf .
I configured my 6k to be two vrf domain, now I can only see the routes which belong to them individully. How can I redistribute the routes between these two vrf domain and let them see peer routes?
Also why there is no routes on the main 6k routing table, only in the vrf routing table?
My purpose is divided this 6k to multiple virtual routers and each router maintain its own routing table.
Below is my confige so far, thanks
ip vrf lab-1
rd 800:2
ip vrf lab-server
rd 800:1
interface Vlan333
ip vrf forwarding lab-server
ip address 172.x.x.1 255.255.255.0
interface Vlan444
ip vrf forwarding lab-1
ip address 10.x.x1 255.255.0.0
router eigrp 444
redistribute connected
redistribute eigrp 333
no redistribute eigrp 444
no auto-summary
address-family ipv4 vrf lab-1
network 10.x.x.x 0.0.255.255
no auto-summary
autonomous-system 444
exit-address-family
router eigrp 333
no auto-summary
address-family ipv4 vrf lab-server
redistribute eigrp
network 172.x.x.x 0.0.0.255
no auto-summary
autonomous-system 333
exit-address-family
paul.matthews
Level 5
Level 5
Under the VRF you need to look at import & export to pass routes from one VRF to another.
Thanks for reply.
#route-target export|import
I saw a cisco document says this command is effective only if BGP is running, what's that mean? Do I need enable BGP on this 6k to enable the redistribute?
