Redistribute BGP learned default route into EIGRP
2044418Puts
I would like to redistribute a BGP learned default route into EIGRP. I'm using the following config:
router eigrp 65101
redistribute bgp 65101 route-map BGP_DEFAULT_ROUTE_RM
passive-interface default
no passive-interface GigabitEthernet0/0
no passive-interface GigabitEthernet0/1
network 1.1.1.0 0.0.0.63
no auto-summary
eigrp router-id 1.1.1.1
router bgp 65101
no synchronization
bgp log-neighbor-changes
bgp redistribute-internal
network 1.1.1.0 mask 255.255.255.192
neighbor 2.1.1.1 remote-as 64000
no auto-summary
route-map BGP_DEFAULT_ROUTE_RM permit 10
match ip address prefix-list DEFAULT_ROUTE_PL
ip prefix-list DEFAULT_ROUTE_PL seq 5 permit 0.0.0.0/0
Using this config (from the BGP Q&A cisco website) I'm not able to get the default route redistributed into the other EIGRP neighbors. The default route isn't in the routing table nor in the topology table.
Anyone any idea's?
I'm using a couple of 2800 series routers and IOS 12.4.24T.
Harold Ritter
Armand,
You need to configure a "default-metric" under the "router eigrp" process for any route to get redistributed into eigrp.
Harold Ritter
Armand,
Yes, you are correct. Found that out a few minutes ago.
Regards.
Is the default in the BGP table ?
ex. sh ip bgp
question :
If there is no default in the BGP table then where and how would the default get into eigrp ?
All your doing in redistribution is taking networks originated in one routing domain and placing them in another routing domain. So if BGP is not originating a default, then no default for eigrp via redist.
