Redistribute static route in eigrp with VRF
Joris Deprouw
Hi all,
I have an issue with my setup of a 6500 switch (12.2(33)SXI9).
We have a 6500 switch with several VRF's. For a certain VRF I would like to redistribute a static route in EIGRP. After doing so I don't see the static route on my eigrp neighbor.
This is a overview of my config. I'm basically redistributing only my static route for this vrf in eigrp.
I found a similar case in which the solution was adding a metric to the static route. (eg. redistribute static route-map static-eigrp-pp metric 10000 100 255 1 1500). But the strange thing is that we don't have this issue on a similar machine (same IOS, same config setup).
Any help appreciated...
Best Regards,
Joris
router eigrp 20
address-family ipv4 vrf TEST
  offset-list 10 out 1 Vlan605
  network 172.23.10.64 0.0.0.15
  autonomous-system 20
  eigrp router-id 172.23.10.66
  nsf
exit-address-family
route-map static-eigrp-pp permit 10
match ip address prefix-list onlydefault
ip prefix-list onlydefault seq 5 permit 0.0.0.0/0
ip route vrf TEST 0.0.0.0 0.0.0.0 172.23.10.17
switch#sh ip route vrf TEST | i 0.0.0.0
Gateway of last resort is 172.23.10.17 to network 0.0.0.0
     10.0.0.0/8 is variably subnetted, 799 subnets, 9 masks
S*   0.0.0.0/0 [1/0] via 172.23.10.17
switch#
switch#sh ip eigrp vrf TEST topology 0.0.0.0  0.0.0.0
EIGRP-IPv4 Topology Entry for AS(20)/ID(172.23.10.66) VRF(TEST)
EIGRP-IPv4(20): Topology base(0) entry for 0.0.0.0/0
  State is Passive, Query origin flag is 1, 0 Successor(s), FD is 4294967295
  Descriptor Blocks:
  172.23.10.65 (Vlan605), from 172.23.10.65, Send flag is 0x0
      Composite metric is (5888/1792), route is External
      Vector metric:
        Minimum bandwidth is 1000000 Kbit
        Total delay is 130 microseconds
        Reliability is 255/255
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
        Originating router is 172.23.10.65
      External data:
        AS number of route is 0
        External protocol is Static, external metric is 0
        Administrator tag is 0 (0x00000000)
        Exterior flag is set
Giuseppe Larosa
Hello Joris,
the feasible distance looks like "infinite" in the 32 bit metric field
I would say for this reason the route is not advertised to the EIGRP neighbor.
the use of a seed metric expressed in the 5 metric components may help
Hope to help
Giuseppe
Hi Giuseppe,
Maybe I didn't explain everything correctly.
In total we have 4 routers.
Router A and B have the same static route configured for vrf TEST.
Router A and B have the same EIGRP AS number with a redistribute static in it.(same config as above)
I guess it is normal they don't see the redistributed static route of eachother since the have the static route configured themselves which has a lower Administrative Distance than the EIGRP redistributed route.
Is that correct?
Now Router C and D are also in the EIGRP 20 group and receive the static route by EIGRP (redistributed by A and B).
The thing is now, C and D only receive it from router B not from router A.
It could well be this is normal behavior, but how does router C and D decide which route will be placed in the routing tabel, since they receive it from both A and B.
If this is normal behavior, both C and D should receive the static route from router A the moment we delete the static route from the config of router B. Is it correct to asume that?
Best Regards,
Joris
