redistributing connected routes into ospf
sarahr202
Level 5
Level 5
Hi everybody
Please consider the following example:
R1--area 0--R2
R1 has loopback addresses:
interface Loopback1
ip address 10.1.1.1 255.255.255.0
ip ospf network point-to-point
interface Loopback2
ip address 10.1.2.2 255.255.255.0
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
redistribute connected metric 1 subnets
network 199.199.199.1 0.0.0.0 area 0
R1 routing table:
C    199.199.199.0/24 is directly connected, Serial0/0
     10.0.0.0/24 is subnetted, 2 subnets
C       10.1.2.0 is directly connected, Loopback2
C       10.1.1.0 is directly connected, Loopback1
My question is about redistribute command.   Please correct me if  I am wrong. My understanding  is when we use the command"  redistribute connected"  under a protocol say under eigrp,  we are telling the router  to  start advertising  the  all the routes present in routing table with "  C'  next to it in eigrp updates.
In our example, I want  R1( acting as ASBR)  to start sending updates about the loopback addresses;   10.1.1.0/24, 10.1.2.0/24  in our ospf domain.
My question  is  when I use the command  :
Should it not cause R1 to start sending updates  about all the routes present in routing table with "  C"  next to them?
When   I use the " Wireshark " on R1's int,  I saw  R1 generating updates (LSA5) about  10.1.2.0/24  10.1.1.0/24 but  not about 199.199.199.0/24 as it shoud  since  this route has "C" next to it in our routing table . (  Please keep in mind we  are already running ospf on 199.199.99.1 s0/0 by using network 199.199.199.0 0.0.0.0 area 0)
thanks and have a great week
Peter Paluch
Hi Sarah,
Your observation is absolutely correct. The redistribute connected command should cause all routes in the routing table flagged as 'C' (connected) to be redistributed into the respective routing protocol.
However, whenever a network command overlaps with a redistribute command, the network command takes precedence. In your case, the 199.199.199.0/24 is not redistributed into OSPF as LSA-5 because it is already considered as an internal network. It will instead be advertised as an internal network. After all, it would be illogical to establish an adjacency over a particular network and yet advertise that network as external (i.e. not belonging to the particular routing protocol).
Best regards,
Peter
Peter Paluch
Hi Sarah,
Best regards,
Peter
Thanks  Peter. It was nice hearing from you after a long time.
