redistributing routes using distribute-list
sarahr202
Level 5
Level 5
Hi everybody
My book says we can use " distribute-list with  " out" option to redistribute routes.
I have been trying to test this feature but I can not get it working.
Below R2 is supposed to redistribute route 1.0.0.0/8 learned via rip into eigrp  using distribute list.
loopback 1.0.0.0/8( R1)-----rip---------f0/0 (R2)---f0/1---Eigrp----R3
R2#show ip route
Gateway of last resort is not set
C    200.200.200.0/24 is directly connected, FastEthernet0/0
C    199.199.199.0/24 is directly connected, FastEthernet0/1
R    1.0.0.0/8 [120/1] via 200.200.200.1, 00:00:22, FastEthernet0/0
router eigrp 1
network 199.199.199.0
default-metric 100 10 255 1 1500
distribute-list 4 out rip
auto-summary
access-list 4 permit 1.0.0.0 0.255.255.255
I am expecting 1.0.0.0 should be redistributed into eigrp and R3 should have it in its routing table:
But It does not:
R3#show ip route
C    199.199.199.0/24 is directly connected, FastEthernet0/0
R3#
I have pasted the show runnning outputs below.
Thanks and have a great weekend.
R1#show running-config
Building configuration...
Current configuration : 959 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip domain name lab.local
voice service voip
no allow-connections any to pots
no allow-connections pots to any
interface Loopback1
ip address 1.1.1.1 255.0.0.0
interface FastEthernet0/0
ip address 200.200.200.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
router rip
network 1.0.0.0
network 200.200.200.0
no ip http server
ip forward-protocol nd
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R1#
R2#SHOW RUNNING-CONFIG
Current configuration : 1063 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
voice service voip
ip address 200.200.200.2 255.255.255.0
duplex auto
speed auto
ip address 199.199.199.2 255.255.255.0
duplex auto
speed auto
router eigrp 1
auto-summary
router rip
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R2#
R3#SHOW RUNNING-CONFIG
Current configuration : 908 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
voice service voip
ip address 199.199.199.3 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
auto-summary
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R3#
Raju Sekharan
Function of Distribute-list is to filter the routes. It cannot do redistribution
You need to use redistribution command for redistribution to work from RIP to EIGRP
Raju
Raju Sekharan
Raju
Hi Raju
That is exactly I thought.  But the book says we can also use distribute-list  with " option"  to redistribute routes into igp
It also gives an example but when i lab it up, I don't see any routes being redistributed.
Thanks anyway.
I would look for a better book, if I were you.
Which book is it? We need to contact the author/publisher to get it corrected if possible.
"distribute-list 4 out rip"
The RIP in the end says to apply the distribute-list only for RIP routes. But still you need redistribution statement
Raju
