Redistributing via eigrp 90 - question
mahesh18
Level 6
Level 6
Hi all,
Good Morning!.
I have this setup .
Router BB   is running EIGRP and is connected directly connected to Router 2650XM.
They connect by serial interface and running EIGRP.
Also Router 2650XM connects to rest of network using OSPF.
Router 2650XM is boundary router doing redistribution ---OSPF into BB  router and EIGRP routes to rest of network.
When i do sh ip route on BB  router
BB#sh ip route 10.1.24.2
Routing entry for 10.1.24.0/30
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Redistributing via eigrp 90************************************************************?????????????????????????????
  Routing Descriptor Blocks:
  * directly connected, via Serial0/0
      Route metric is 0, traffic share count is 1
BB#sh ip eigrp nei
IP-EIGRP neighbors for process 90
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   10.1.24.2               Se0/0             14 5d13h       1   200  0  158
My question is when i do sh ip route 10.1.24.2  why does it show  redistributing via eigrp 90???????????
as this is directly connected route to 2650XM Router?
Mahesh
2 Accepted Solutions
Richard Burts
Mahesh
I can tell you that this is a common behavior but I do not have a good explanation of why it says redistributing via eigrp when it is a connected network being advertised throgh eigrp. Perhaps one of the Cisco engineers has an explanation of why it says this. But I believe that if you do show ip route for any connected interface prefix that is advertised by a network statement in eigrp that you will see the same thing of redistributing via eigrp.
Rick
Rick
Hi Mahesh,
That is because the default route is redistributed to EIGRP and that is why you see 170 (External) after 0.0.0.0
7 Replies 7
Richard Burts
Mahesh
Rick
Rick
Hi Rick,
thanks for reply.
I checked this--- show ip route for any connected interface prefix that is advertised by a network statement in eigrp that you will see the same thing of redistributing via eigrp.
You were right on this it shows all as redistributing via eigrp.
MAhesh
Rick,
I agree, this is so weird.  When the route is Internal, it shows it as redistributed.  The only explanation I can see is when you look at the topology, it says:
So, I guess EIGRP thinks since the route originally is known via connected, and now since you added it to EIGRP, this is a redistribution, but the metric is still 90.
Reza
Reza Sharifi
Hi Mahesh,
Since this interface is part of EIGRP, as far as EIGRP KNOWS the admin distance is 90 (internal) which is correct, but your routing table shows as connected.
If you redistribute a static route or from other protocols to EIGRP, than the admin would be 170 (external).
Hi Reza,
Thanks for reply
I did sh ip route
C       10.1.24.0/30 is directly connected, Serial0/0
It shows as connected  with no admin distance that makes sense as it is directly connected and AD is 0 for directly connected.
But when i do sh ip route on BB  at bottom it shows
D*EX 0.0.0.0/0 [170/26137600] via 10.1.24.2, 00:00:04, Serial0/0
i know 10.124.2 is my default route .
But do you know why it shows D.EX   there?
MAhesh
Hi Mahesh,
Hi Rick and Reza,
Many thanks for you replies.
MAhesh
