2960 flex switch stack
bakerrh75
2960 switch stack (flex) Spanning tree re-calculate from stack port one?
I need to identify with port in the stack is causing the re-calc I have four 48 port switches and show spanning detail only indicates stack port 1 any ideas to sh which port this is from ?
Reza Sharifi
Can you post the output of show spanning detail?
If the port is 1/0/1 than that is switch 1 port 1
if the port is 2/0/1 than that is switch 2 port 1
Hopefully, your switches are labeled with the corresponding number, so you know for example switch 4 is the one at the bottom.
