REDISTRIBUTION
fb_webuser
Level 6
Level 6
Here is a problem.I want to communicate between one OSPF and one EIGRP network.I enabled redistribution in the border routers.But they are unable to communicate Here is the link of the sample file
http://www.mediafire.com/download/48g4cjpqdhtfhlz/redistribution.pkt
Thank u
Posted by WebUser Anik Biswas from Cisco Support Community App
7 Replies 7
Hello
unable to see your topology however
mutual redistribution should work fine as long as you make sure you dont created route feedback between the tow protocols and this can be easlily accomplished by routemaps and denying on the protocol admin distance
Sent from Cisco Technical Support Android App
Kind Regards
Paul
fb_webuser
Level 6
Level 6
how to deny protocol admin distance?
Can you post the code that you are using for redistribution?
Hello
On.the border routers which are perfroming mutual redistribution
Route-map EO deny 10
match tag 110
Route-map EO permit 99
set tag 90
Route-map OE deny 10
match tag 90
Route-map OE permit 99
set tag 110
router eigrp xx
redistribute ospf x route-map OE metric 1 1 1 1 1
router ospf x
redistribute eigrp xx route-map EO subnets
res
paul
set tqent from Cisco Technical Support Android App
Kind Regards
Paul
fb_webuser
Level 6
Level 6
fb_webuser
Level 6
Level 6
The above is the link for the packet tracer file
Mediafire is blocked in my org.
Also, in your original post, what do you mean by unable to communicate?
