Reduce broadcast traffic between 2 locations
qus83
Hi all
we have problem regarding to traffic via mpls between 2 locations
in main office we have
 core c3850 stack 192.168.1.1
access c3650 stack connected to servers, printers
vlan 120 for servers , vlan 130 voice
and the branch location
cisco c3650 switch
they asked me to replace the switch and add new vlan to reduce the broadcast traffic but the vlan is in the same range as  core (192.168.1.90)
the problem is as long as the vlan in same range we can not reduce the  broadcast traffic and it should be in this range because all the servers are located in main office
we can not use the same subnet cuz we will face the same problem
we should  create new subnet to reduce the traffic but the problem we should connect to the servers vlan 102 in main office so it will pass through the vlan102
so how we can solve this problem ?????
andresfr
Hi Qus83,
So, is the connection between the two sites a Layer 2 MPLS?
If so, you could have a trunk between the two sites so you can pass traffic for multiple VLANs:
Site_A_SW-------Trunk-------L2 MPLS-------Trunk-------Site_B_SW
Then, if you want devices in VLAN 120 to communicate with devices in a different/new VLAN (let's say VLAN 102) you could configure VLAN SVIs on those switches so you can have inter-VLAN routing:
Site_A_SW# configure terminal
Site_A_SW(config)# interface vlan 120
Site_A_SW(config-if)# ip add <ip_address> <network_mask>
Site_A_SW(config-if)# no ip redirects
Site_A_SW(config-if)# no ip directed-broadcast
Site_A_SW(config-if)# exit
Site_A_SW(config)# interface vlan 102
Can do the same on Site_B_SW. In that way you'll have the new VLAN to reduce the broadcst domain and devices in each VLAN should be able to communicate using inter-VLAN routing if their default-gateway is set to the IP address configured for the VLAN they belong to.
I hope this helps.
Hi Andresfr
Thanks for your reply
in main office the vlan server (120), voice vlan (130) and all vlans are already configured so the problem the high traffic between main office and branch (trunk already configured between them)
Site_A_SW(config-if)# ip add 192.168.20.1
Site_A_SW(config)# interface vlan 130
Site_A_SW(config-if)# ip add  192.168.30.1
in Branch office they want connected to servers in main vlan 120 and voice
so should I configure new vlan with new range like below
Site_B_SW(config)# interface vlan 102
Site_B_SW(config-if)# ip add  192.168.2.1
and beside that configure vlan server and voice again here in the branch
Site_B_SW# configure terminal
Site_B_SW(config)# interface vlan 120
Site_B_SW(config-if)# ip add 192.168.20.1
Site_B_SW(config-if)# no ip redirects
Site_B_SW(config-if)# no ip directed-broadcast
Site_B_SW(config-if)# exit
Site_B_SW(config)# interface vlan 130
Site_B_SW(config-if)# ip add  192.168.30.1
AND gateway will be to mgm ip 192.168.1.1 for core in main
Please correct me if i'm wrong ??
depending on the number of clients, a way to reduce broadcast traffic would be to add static ARP entries for all your clients and servers, on all participating switches.
Hi Georg
so you mean it doesn't need to create new vlan only add static arp in global configuration mode ???
