redundancy between 3650 switches without stack
engsyed.net1
Hi, I want  to configure C3650 2 switches with redundancy (without stack module / cables ) I'm using only one subnet as DHCP, among switches there will be only one default gateway (switch 1) having DHCP, (switch 2 without DHCP), in this scenario if switch 1 goes down DHCP will not work with standby switch (Switch 2)
attached topology
can any one help me guide the solution :
Reza Sharifi
In order to provide complete redundancy for your DHCP server, it needs to be connected to both 3650 switches. You also need to stack the switches.
Reza Sharifi
