Redundancy Edge Sw
melwin.uk
2960 needs reachability to backbone-sw when link between 2960 and 4509 is down
4509 is the server, All 2960 will be VTP client
On 4509
interface gi 0/1
switchport trunk encap dot1q
switchport mode trunk
interface gi 0/2
interface gi 0/3
On 2960 ( 1st floor )
interface gi 0/1
interface gi 0/2
On 2960 ( 2nd floor )
interface gi 0/1
interface gi 0/2
On 2960 ( 3rd floor )
interface gi 0/1
interface gi 0/2
Any additional configuration is needed to avoid loop if both connection port is up on 2960.
Mel
Jon Marshall
Melwin
No additional configuration needed as STP will automatically block one of the uplinks. I would recommend running RSTP rather than standard PVST+ as it is a lot quicker to failover and make sure the 4500 switch is STP root for all vlans.
Jon
Do I need additional configuration on 4509 for RSTP then mentioned.
Is any config needed on 2960 edge switches for RSTP
Switch(config)# spanning-tree mst configuration
Switch(config-mst)# instance 1 vlan 10-20
Switch(config-mst)# name region1
Switch(config-mst)# revision 1
melwin.uk wrote:
Melwin
The above is config for MST not rapid-pvst+. See the attached docs for rapid-pvst+ config -
4500 -
4500 rstp
2960 -
2960 rstp
Jon
