Netflow anyalyser
sharma16031981
Level 3
Level 3
Hi All,
I am facing problem configuring netflow anylyser.
When I open console of netflow analyser. It show name of router and interface name for only two router for other it show IP address and interfaces as IFINDEX 1or 2 like that. Though the configuration of all router is same.
If someone can help to check what is the issue or any command to check whether router support that or not. It says MIB unknown in the netflow GUI for all other router. What is MIB and how to configure that.
Hemant
sean_evershed
Level 11
Level 11
Hemant
- Have you configured SNMP on your routers with a community string? Does it match the string you have configured on your netflow analyser?
- Is there a firewall between the netflow analyser and your routers?
If you issue the following command you can match the MIB value to the interface name:
R1#SH SNMP mib ifmib ifindex
FastEthernet0/0: Ifindex = 1 Null0:
Ifindex = 8 VoIP-Null0:
Ifindex = 7 Serial1/0:
Ifindex = 3 Voice Over IP Peer: 1:
Ifindex = 9 FastEthernet0/1:
Ifindex = 2 Serial1/1:
Ifindex = 4 Serial1/2:
Ifindex = 5 Serial1/3:
Ifindex = 6 EFXS 50/0/1:
Ifindex = 10 Voice Encapsulation (POTS) Peer: 20001: Ifindex = 11
Ganesh Hariharan
Hi All,
Hemant
Hi Hemant,
A MIB by defination is a management information base (MIB) is a formal description of a set of network objects that can be managed using the Simple Network Management Protocol (SNMP). The format of the MIB is defined as part of the SNMP.
As suggested check out the snmp stirng and see the below link for best practices for deployment of netflow analyser
http://www.manageengine.com/products/netflow/nfa_best_practices.pdf
http://www.manageengine.com/products/netflow/help/cisco-netflow/cisco-ios-netflow.html
Hope to Help !!
Ganesh.H
If helpful do rate the post
Giuseppe Larosa
Hello Hemant,
as noted by Sean the netflow analyzer has to perform an SNMP get for SNMP ifindex table in order to resolve ifindexes in interface names
The OID can be seen in
http://www.alvestrand.no/objectid/1.3.6.1.2.1.2.2.1.1.html
a single get receives as answer the list of all defined ifindexes
the OID is:
.iso.org.dod.internet.mgmt.mib-2.interfaces.ifTable
more exactly you need
.iso.org.dod.internet.mgmt.mib-2.interfaces.ifTable.ifEntry.ifDescr
For each router this SNMP query has to be done by the netflow analyzer
I would expect that you need to add IP addresses or router names in some txt config file in order to have these queries done on the netflow analyzer.
Hope to help
Giuseppe
