Redundand supe rebooted 6509
mahesh18
Level 6
Level 6
Hi all,
On switch cisco WS-C6509-E   we have  standby supe got rebooted.
here is logs
000123: Mar  6 23:48:47.100 EST: %OSPF-5-ADJCHG: Process 3738, Nbr x on TenGigabitEthernet6/5 from FULL to DOWN, Neighbor Down: Interface down or detached
000124: Mar  6 23:48:47.116 EST: %PIM-5-NBRCHG: neighbor x  DOWN on interface TenGigabitEthernet6/5 non DR
000125: Mar  6 23:48:47.248 EST: %SNMP-5-MODULETRAP: Module 6 [Down] Trap
Mar  6 23:48:47.232 EST: %OIR-SP-3-PWRCYCLE: Card in module 6, is being power-cycled (Slot disabled)
Mar  6 23:51:27.865 EST: %PFREDUN-SP-6-ACTIVE: Standby initializing for SSO mode
Mar  6 23:51:28.061 EST: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Mar  6 23:51:29.409 EST: %PFINIT-SP-5-CONFIG_SYNC: Sync'ing the startup configuration to the standby Router.
Mar  6 23:51:52.846 EST: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
Mar  6 23:51:52.846 EST: %FABRIC-SP-5-FABRIC_MODULE_BACKUP: The Switch Fabric Module in slot 6 became standby
Mar  6 23:52:05.870 EST: %DIAG-SP-6-RUN_COMPLETE: Module 6: Running Complete Diagnostics...
Mar  6 23:52:07.947 EST: %DIAG-SP-6-DIAG_OK: Module 6: Passed Online Diagnostics
000126: Mar  6 23:52:10.970 EST: %SNMP-5-MODULETRAP: Module 6 [Up] Trap
Mar  6 23:52:10.973 EST: %OIR-SP-6-INSCARD: Card inserted in slot 6, interfaces are now online
000127: Mar  6 23:52:20.506 EST: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to x.x.x.x  on interface TenGigabitEthernet6/5
000128: Mar  6 23:52:22.118 EST: %PIM-5-NBRCHG: neighbor x.x.x.x  UP on interface TenGigabitEthernet6/5
00:01:17: %SYS-SPSTBY-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:01:46: %DIAG-SPSTBY-6-RUN_COMPLETE: Module 6: Running Complete Diagnostics...
00:01:55: %DIAG-SPSTBY-6-DIAG_OK: Module 6: Passed Online Diagnostics
00:02:16: %SYS-SPSTBY-5-RESTART: System restarted --
Cisco IOS Software, s72033_sp Software (s72033_sp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXH3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 24-Jul-08 19:35 by prod_rel_team
00:02:16: %PFREDUN-SPSTBY-6-STANDBY: Ready for SSO mode
000129: Mar  6 23:52:29.906 EST: %OSPF-5-ADJCHG: Process 3738, Nbr x.x.x.x  on TenGigabitEthernet6/5 from LOADING to FULL, Loading Done
00:02:16: %SYS-SPSTBY-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Supe is 720 10 GB
#sh mod
Mod Ports Card Type                              Model              Serial No.
  1    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  2    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  3    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE
  4    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G
  6    5  Supervisor Engine 720 10GE (Hot)       VS-S720-10G
  8   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP
  9   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP
Can someone explain we what happedned to supe 6 as per logs above
thanks
mahesh
2 Accepted Solutions
meperuma
Your stdby sup was reloaded. May be due to sw/hw.
1) check show diagnostic events - for any diag failure on module 6
2) look out for any crash info generated on the stdby sup before the crash. Check the stdby bootflash, sup-bootdisk or disk0. If you have the crash info, provide that here or you can open a tac case.
3) if you dont have any crash info or no diag failure, monitor the sup for next few weeks, if the same symptom occur again, replace it.
Hello Mahesh,
From below two logs it is difficult to dictate what had happened with slot-6
I advise you to take below output and submit it to cisco Tac
> sh-tech
> output of crashinfo if it is generated (you can run command dir all-filesystem and search for crashinfo file)
> tacacs log during that time to find out trigger of this issue.s
Hope this helps
Regard
Mahesh
oh I see issue is already resolved
Message was edited by: mahesh Gohil
5 Replies 5
meperuma
Hi Meenakshi,
thanks for reply.
we open cisco tac case
as per tac because of a parity error.
many thanks
mahesh
Hi Mahesh,
Glad to know that you found the cause :-)
May be just to make sure your 6500 is grounded properly to eliminate any electro statics
Hello Mahesh,
> sh-tech
Hope this helps
Regard
Mahesh
Hi Mahesh,
Thanks for your reply.
mahesh
