Redundant 4506 supervisor
edatwyler
I have "inherited" a Catalyst 4506 with IOS version 12.2(20)EWA1 and Supervisor IV already installed.  We recently purchased a second Supervisor IV and I am looking to install this second supervisor for redundancy.  Is there anything special with installing a second supervisor or so I just physically install the new supervisor and the IOS will automatically set everything up?  I've been searching and I can't really find any documents about how to do this.  Thanks!
2 Accepted Solutions
Oleg Volkov
Hi!
You need have an identical  IOS on both Supervisor (and identical hardware)
Supervisor engine redundancy is configured by default, but You can manually synchronized configuration as next:
Switch(config)# redundancy
Switch(config-red)# main-cpu
Switch(config-r-mc)# auto-sync standard
Switch(config-r-mc)# end
Switch# copy running-config startup-config
You can read more information on this doc
Helping seriously ill children, all together. All information about this, is posted on my blog
sansarav720e
Dear ed ,
        what is your switch model its 4506 or 4507 , if it 4506 it wont support for supervisor redudancy , because it has got only one supervisor slot , slot no 1
kindly look into below link for switch chasis comparison
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html#~two
Thks
santhosh sarav
HTH Regards Santhosh Saravanan
Oleg Volkov
Hi!
sansarav720e
Dear ed ,
Thks
santhosh sarav
It's a 4506 chassis.  Thanks for the information guys.
