Redundant supervisor engine will forward the data while is standby ?
Rajkumar Singaram
Community Member
We bought Cisco sup engine WS-SUP32-GE-3B for 6500 switches 2 nos for redundancy. I have connected 6 systems on each sup engine ports.
Anyone clarify whether both sup engine will forward the data while one is Master and other is standby ?
S.Raj
Reza Sharifi
In SSO mode, the primary sup will forward traffic and the stand-by is waiting until the primary goes down and then it starts forwarding traffic.  If you create on etherchannel using one port from each sup, it will use the primary sup to forward traffic.  If you pull out the the primary sup, it will fail over to the stand-by sup and the port on the stand-by will forward traffic.  I have not tested this on sup-32, but I know it works well with sup-720
Hi Raj,
When you have two SUP's for redundancy one is active and other is standby.
Incase if the active (primary) supervisor engine is down then the whole traffic will handle with the standby (secondary) supervisor engine without any outage.
Please rate the helpfull posts.
Naidu.
Joseph W. Doherty
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
Generally the standby sup doesn't forward packets even when you can use its ports.  An exception is the VSS-720 which also uses the standby sup to increase chassis forwarding capacity.  (NB: This is not to be confused with VSS between chassis.)
PS:
Similarly, 3750 stack masters make L3 forwarding decisions for the whole stack.
dominic.caron
Level 11
Level 11
When you are using the port on the standby supervisor on a sup32, it will work. You need to be aware that L2 or L3 forwarding is only done by the active supervisor.
In other word, if a frame arrive on the first port of the standby sup and it need to get forwarded to the second port on the same sup, the frame will first go to the active sup using de classic BUS and come back down to be transmitted.
