10-19-2015 01:41 AM - edited 03-08-2019 02:16 AM
Can I use Reflexive ACL with port forwarding to listen incoming traffic towards inside web server?
Solved! Go to Solution.
10-19-2015 06:58 PM
Do you mean use reflexive acl for traffic going out to the internet from internal clients to allow return traffic back in and at the same time allow connections from outside to a specific inside server for certain ports ?
If so yes you should be able to do that.
Basically your acl applied inbound on your outside interface would allow the traffic to your web server and nothing else and the reflexive acl part then adds temporary entries to that acl for return traffic to clients.
Is this what you are asking ?
Jon
10-19-2015 08:34 AM
Hi Zarni,
Reflexive ACL are known as IP session filtering which work in conjunction with ip extended named ACL.
For doing port forwarding using ACL on router, check out the below link for more information.
https://supportforums.cisco.com/discussion/11835581/port-forwarding-access-list
Hope it Helps..
-GI
Rate if it Helps..
10-19-2015 06:58 PM
Jon
