Reg:Network Moniter
Hi Team,
In my company,We have installed OP Manager in our server.here we have c3750 switch,how I configure SNMP trap for moniter the cisco device cpu,memory and bandwidth utilization.
Kindly help to moniter my device.
Thanks and Regards,
Mohamed kabeer.S
Hi Mohamed ,
 use below link for configurations support . which version of SNMP you are running on your OP Manager
Table 33-1 SNMP Security Models and Levels
Model
Level
Authentication
Encryption
Result
SNMPv1
noAuthNoPriv
Community string
No
Uses a community string match for authentication.
SNMPv2C
noAuthNoPriv
Community string
No
SNMPv3
noAuthNoPriv
Username
No
Uses a username match for authentication.
SNMPv3
authNoPriv
Message Digest 5 (MD5) or Secure Hash Algorithm (SHA)
No
Provides authentication based on the HMAC-MD5 or HMAC-SHA algorithms.
SNMPv3
authPriv
(requires the cryptographic software image)
MD5 or SHA
Data Encryption Standard (DES) or Advanced Encryption Standard (AES)
Provides authentication based on the HMAC-MD5 or HMAC-SHA algorithms. Allows specifying the User-based Security Model (USM) with these encryption algorithms:
DES 56-bit encryption in addition to authentication based on the CBC-DES (DES-56) standard.
3DES 168-bit encryption
AES 128-bit, 192-bit, or 256-bit encryption
You must configure the SNMP agent to use the SNMP version supported by the management station. Because an agent can communicate with multiple managers, you can configure the software to support communications using SNMPv1, SNMPv2C, or SNMPv3.
Let me know  , if you are looking for any support on this .
Sandy
