QoS shaping on Port Channel sub interface
sylvain.munaut
I have a 1921 in a 'router on a stick' configuration. It's connected to the switch using a redudant etherchannel.
interface Port-channel 1
no shut
interface GigabitEthernet0/0
no ip address
no mop enabled
channel-group 1
interface GigabitEthernet0/1
no ip address
no mop enabled
channel-group 1
interface Port-channel1.1
encapsulation dot1Q 1 native
ip address 10.1.0.1 255.255.255.0
interface Port-channel1.2
encapsulation dot1Q 2
ip address 10.2.0.1 255.255.255.0
Now I'd like to apply some shaping on the traffic exiting Port-channel1.2 so I tried:
policy-map policy_upload
class class-default
  shape average 100000
  set ip precedence 0
service-policy output policy_upload
But that didn't work at all, no reduction in bandwidth.
If I try the same thing without the port channel, then it works fine.
Any suggestion ?
Cheers,
    Sylvain Munaut
5 Replies 5
andrew.prince
Level 10
Level 10
Virtual interfaces sometimes work in the opposite direction, so try it on the "inbound", also post the output of "show policy-map interface
Port-channel1.2"
I can't put it as input because :
gw-a(config-subif)#service-policy input policy_upload
Traffic Shaping feature not supported in input policy.
Here's a show during a bandwidth test. You can see the offered rate is properly measured and is _way_ above the target shape rate.
gw-a#show policy-map interface Port-channel 1.2
Port-channel1.2
  Service-policy output: policy_upload
    Class-map: class-default (match-any)
      624006 packets, 842239036 bytes
      5 minute offered rate 12774000 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
      shape (average) cir 100000, bc 400, be 400
      target shape rate 100000
Hi!
did you find any solution on your problem? couse i have the same issue now
It works now. AFAIR I just updated IOS ....
Huge THANKS for quick reply!
This was my first guess, after i`ve tryed everythin, but this device has latest iOS from cisco.com
I`ll try on other device, which is not currently updated yet.
Thanks!
