Regarding sh port-channel load-balance.. how can i undo this?
darulkutteni
HI Forumer,
can we undo the cmd "sh port-channel load-balance"? need help from forumer here.
TQ
DK
6 Replies 6
jimmysands73_2
Level 5
Level 5
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_o1.html#wp1013233
To set the load distribution method among the ports in a bundle, use the port-channel load-balance command in global configuration mode. To reset the load distribution to the default settings, use the no form of this command.
port-channel load-balance method module slot
no port-channel load-balance
if my config as this
sh port-channel load-balance forwarding-path interface Po139 src-ip 10.2.16.17 dst-ip 10.2.18.63 vlan 620 src-mac 0015.5d07.ea17 module 3"
so i need to put it like this
" no
please advice.
Your asking about a show command, if you dont want to see anything, just dont type it
I think we are having a language barrier.
If you want to put load balancing back to the defaults, you should just have to type no port-channel load-balance, but are you sure this is what you want to do?
From searching Cisco site, looks like you are using a Nexus.  I have zero experience with Nexus, so I am going to defer to someone else who might want to chime in to assist you this morning so I do not give you bad/incorrect info.
anyway thanks jimmy. u are correct this from nexus 7k.
Any forumers that have experience with nexus?
This article might help:
Its for the 5000 series though
Message was edited by: Jimmy Sands
Sent to early, here is the config guide for the 7k
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/interfaces/configuration/guide/if_portchannel.html
And in it it says:
Use the no port-channel load-balance ethernet to restore the default load-balancing algorithm of source-dest-mac for non-IP traffic and source-dest-ip for IP traffic.  You can browse the doc though to make sure this is the right one.  Good luck.
