ā07-03-2024 08:02 AM
If we create acl to any Vlans segment for one direction traffic then will be need to create Acls for other direction traffic also or not. Kindly help me any one for giving suggestion.
Thanks to all
ā07-03-2024 08:17 AM
it depend on you,
you can config ACL with one direction or two direction
MHM
ā07-03-2024 12:03 PM
@MHM Cisco World wrote:
it depend on you,
you can config ACL with one direction or two directionMHM
I would suggest is depends more on what you want to accomplish, and the nature of the traffic.
Much traffic requires two way communication to work, blocking such traffic in either direction will effectively block such two way communication.
When blocking traffic, ideally, you want to block ASAP, this to avoid such traffic needlessly flowing across your network infrastructure.
