How to specify the static IP-to-MAC map for dhcp pool
qilin zhang
Dears,
When I use ip dhcp pool cmd on Cisco Router to provide dhcp server service for pc and phones, how can I assign the fixed IP address according to the MAC address of the phones and PCs. I can't find the cmd.
Thanks.
Qilin
You can do it without configuring multiple pools as of IOS  12.3(11)T
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t11/feature/guide/gtdhcpsm.html
Regards.
Alain
10 Replies 10
Andrew Cink
You have to make a custom "pool" for each host... like:
ip dhcp pool TestReservation
host 172.16.2.254
hardware-address 02c7.f800.0422 ieee802
client-name testPCone
domain-name mydomain.com
Why it's not work?
Thank you very much.
what exactly do you have configured ? Post the configuation you have...
ip dhcp pool static
 host 192.168.184.183 255.255.255.0
 hardware-address bce1.43d4.16b1
 default-router 192.168.183.1
 dns-server x.170.119.9 x.170.119.19 8.8.8.8 8.8.4.4
Nandan Mathure
Hi Qilin!
ip dhcp pool HOST2
 host 192.168.1.2 255.255.255.0
 hardware-address aaaa.aaaa.aaaa
ip dhcp pool HOST3
 host 192.168.1.3 255.255.255.0
 hardware-address bbbb.bbbb.bbbb
Or you can use "clien-identifier" instead of "hardware-address"
client-identifier 01aa.aaaa.aaaa.aa [just add 01 as pre-fix] some hosts use client-indentifier.
Please go throught this document:
http://www.cisco.com/en/US/docs/ios-xml/ios/ipaddr_dhcp/configuration/12-4t/config-dhcp-server.html#GUID-C1DE449D-3B56-4832-AE3F-7F82E94E5510
Let me know if this helped.
Nandan Mathure
Hi Nandan,
Fine, but if I have a lot of clients will use IP-to-MAC map, so is there any simple way to input the map? or I have to input the entries one by one?
Qilin
As per my knowledge you will have to do it manually. I totally agree that lot of manual work but ultimately thats what we want to achieve .
Kindly rate if useful. Thanks.
Nandan Mathure
Regards.
Alain
nice to know an input txt file
Best Regards
Giuseppe
Hi, the link stopped working, could give a right one please?
