11-13-2006 10:51 AM - edited 03-05-2019 12:47 PM
Hi all,
I have a router that is completely dead: no flash, no nvram, nothing. I have an IOS image on my laptop which I am trying to load back onto the router.
When in rommon mode, I am getting the following error when I run the tftp command:
rommon 15 > tftpdnld
IP_ADDRESS: 169.254.160.219
IP_SUBNET_MASK: 255.255.0.0
DEFAULT_GATEWAY: 169.254.160.255
TFTP_SERVER: 169.254.169.218
TFTP_FILE: c2600-i-mz.122-5d.bin
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n: [n]: y
ARP: address resolution for 169.254.169.218 timed out.
ARP failed with failure code 1. TFTP transfer aborted.
TFTP: Operation terminated prematurely.
I have tried various gateway address with the same result. My laptop has the image on it, and I've connected to e0/0 via a crossover ethernet cable. I am using tftpd32.
Help!
Thanks!
Chris
11-13-2006 11:03 AM
Hi Chris ,
The key here is that it uses the e0/0 interface and the gateway must be on
that same segment. Remember that from rommon this router is only a host on the network. It looks and acts like an end device and has no routing capability at all. If the default gateway is not directly connected to the
e0/0 interface then the process will fail.
***The error message here gives you a clue to the problem. It sent an ARP request for 169.254.169.218 and did not receive a response. That indicates that 169.254.169.218 is not directly connected to the e0/0 interface.
Check the below link for tftpdnld procedure.
http://www.cisco.com/warp/public/471/76.html
Also you can try uploading IOS using xmodem command.Check the below link for xmodem procedure.
http://www.cisco.com/warp/customer/701/59.html#rommon
connect laptop to router using console cable and follow the steps mentioned in doc.
All the best..plz rate it..
satish
11-13-2006 01:21 PM
Ok, but something is wrong here.
This is only a test router I have at work, and in actuality it only has ONE interface! LOL. e0/0.
Now, I am doing tftp for the first time, and what I did was copy the IOS from this router to the laptop in the same exact manner I am now trying to copy it right back (I have since completely wiped the flash and nvram).
But nothing changed from copying off to copying back on, other than wiping the router completely.
I have links on both the router e0/0 and laptop. Crossover cable in use.
I cannot ping the router from the laptop and obviously I cannot ping the laptop from the router.
They are connected, and like I said, this was the same setup i used to dump the IOS off the router in the first place.
Help!
11-13-2006 01:33 PM
Nevermind...
For some reason, I rebooted the router, tried again, and this time it felt like working... Silly!
Chris
11-13-2006 01:34 PM
Hi ,
Great ............ 🙂
thanks,
satish
