Reload Switch 4510R
jorge.osorio
I have a switch 4510R and in any time ocur reset. The show ver show me that System returned to ROM by reload.
What happend?
The switch have two electric sources.
Tim Smith
Level 4
Level 4
Someone has logged into your switch and issued the reload command.
If it was a power failure or reset, you would see the message "System returned to ROM by power on" I believe.
I would ensure you have syslog logging turned on on your switch and this should capture and log any reload commands.
Cheers,
Tim.
