Reloading a 4507/4510RE switch with dual sup
gautamzone
Dear Friends,
While reloading a switch with multiple sups, the reload command reloads just the active supervisor. Right?
Is there any command to reload both the sups together? I am talking about 4507/4510RE switches with IOS 12.2(50)SG.
Or the only solution is to type reload twice, once for the active sup and once for the standby sup because it became active?
Thanks a lot
Gautam
Mark Yeates
Level 7
Level 7
Gautam,
The reload command will reboot the entire switch. It does include both supervisors.
HTH,
Mark
Thanks a lot Mark
agugger
Hi Gautam
Check ones the command below:
redundancy reload {peer | shelf}
see also other commans like:
redundancy force-switchover
