Is your switch L3? I mean is the switch doing all the routing for the internal LANs?
What firewalls are you using? Cisco PIX, or ASA or another make?
Sometiems its good to put a router to terminate the WAN connection because you need policy based routing, but if thats not needed it's fine to terminate on a firewall. Each has advantages/disadvantages, routing being one of them, and security being another. But then if the WAN (MPLS) is prviate you shouldn't have security concerns.
The same really goes for internet access. Depends. Each design is valid. Again if you had multiple lines you could use PBR to send traffic down each line and a router is better for that.
I can say that I worked with a large network and we had both. The WAN (MPLS) was conected directly to firewalls. We also had remote offices connected to a Cisco 7513 directly and then to a firewall. The internet was connected directly to a firewall. When I say directly I mean logically. Physically it was all connect to core switches at layer 2 and then the L3 IP was either configured on the firewall or a router.
HTH,
Ian
