Remote Span Trouble
danielpezoa
Hello.
I have the following configuration.
switch 1 (3560)
monitor session 1 source interface Fa0/5 , Fa0/8 , Fa0/10 , Fa0/12 , Fa0/14 - 15 , Fa0/19
monitor session 1 destination remote vlan 40
monitor session 2 destination interface Fa0/23
monitor session 2 source remote vlan 40
switch 2 (3560)
monitor session 1 source interface Fa0/17
vlan 40 has been created as vlan of remote span in both switches, and are allowed in the trunking on both sides.
If i put a sniffer in the interface Fa0/23 of the switch 1, i only see the traffic of interface Fa0/17 of the switch 2. I expect to see also the traffic of interfaces Fa0/5 , Fa0/8 , Fa0/10 , Fa0/12 , Fa0/14 - 15 , Fa0/19 of the switch 1.
Thanks in advance
s.arunkumar
Level 3
Level 3
I think its config mistake.if u would like to see the traffic for int Fa0/5 , Fa0/8 , Fa0/10 , Fa0/12 , Fa0/14 - 15 , Fa0/19 then ur session 1 destination should be towards fa0/23,ie session 1 should be local span.here ur session 1 is mirrored towards the vlan 40 not towards fa0/23.
"monitor session 1 destination interface fa0/23"
