Remote VPN with Cisco 2611 and Fios
Eddie Sardinha
Hi All,
I am looking for some guidance on how I can configure my cisco 2611 router with my fios connection and set up a remote VPN?  I want to use it this way so its always on and I can use it to study for my CCNA.  Do I have to bypass my fios router and put it into bridge mode?
6 Replies 6
Reza Sharifi
To use the router as VPN server, you would need an IOS with security package installed.
What is the output of "sh ver"
Also, remember that the 2600 series routers are very old, slow and very limited IOS image availability.
Thanks, I will get the output
The output of the sh ver is
Router1>sh version
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(40a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Sun 11-Mar-07 01:33 by pwade
Image text-base: 0x8000808C, data-base: 0x80A1ED84
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
System image file is "flash:c2600-i-mz.122-40a.bin"
cisco 2611 (MPC860) processor (revision 0x203) with 20480K/4096K bytes of memory        .
Processor board ID
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
This image does not support VPN. You need an image with k9(crypto).
image example:
2600x-universalk9-mz.152-2
Thanks, I can get the image but how can I configure the router with my fios connection in order to establish the VPN?
Here is sample configuration.
http://www.cisco.com/c/en/us/support/docs/cloud-systems-management/router-security-device-manager/70374-router-remotevpn-sdm.html
I think, the first thing you need to figure out is, can the FIOS modem physically work with the 2600? if yes what is the speed?  And the second thing, can you configure the interface that connect to the modem to get a public IP from the provider's DHCP server? Or do you have extra pubic IP you can use?
