remove console password for 2960 switch
petercinvest
someone setup console password, how to remove it and bypass it, I can't go to priviledge mode because of this console password
Mark Malone
you will need to do a password recovery follow this doc same proc for 2960, it will be service effecting
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/12040-pswdrec-2900xl.html
thank you for your reply, when IOS boot, I use teraterm under menu control/, I send break, but it has no effect. kindly help
it also say "interrupt within 5 seconds to abort boot process", how to change it to one minute?
you dont use ctrl break for your model , you have a mode button on 2960 you hold that in while its booting and it goes to switch: mode from there you foollow the doc on how to reset it
you cant change the interrupt timer on any model its built in but you dont require it here anyway
Dear Cisco expert,
I follow the sugestion, using mode, enter into boot after rename config.old, but it prompts me for entering : n to discontinue config dialog, thus I enter to the situation that asking me for console password again, it fails the recovery.
also load_helper is not working, it says no such command
can you suggest something?
