Removing a switch c9300 from a stack
kentdlane
Visitor
Hi guys,
I removed a switch from stack renumbered it and tried "switch clear stack-mode" but it still shows "switch 1 provision c9300-48uxm" in the config..
When I try to run "no switch 1 provision" I'm getting this error "Error: A switch is already physically present at this location"
Also when I use "write erase" on it i get the same config after reloading it..
Could someone help me out with this one, please?
Just received a call from support.
These strings mean the switch is ready to work in a stack and there is no such thing as un-provisioning it.
6 Replies 6
balaji.bandi
Couple of questions :
1. you mentioned you removed the switch from stack - how many switches were in the stack, what switch you removed ?
2. when you configuring single switch you only have 1 switch. change the switch number and priorty and join to exisitng stack
before joining what is exiting stack switch and numbering ?
3. what switch show this ? switch 1 provision c9300-48uxm
post show run from exiting stack and the one you trying to conguring to understand the issue correctly.
BB
kentdlane
Visitor
Also every time during the boot is logs
"Both links down, not waiting for other switches
Switch number is 1"
Can i know what was the exact resolution . Even i am facing the same issue.
benningtonre
Community Member
I would like to know as well, i am getting ready to pull one 9200 out of a three switch stack.
I will be pulling number three.
Thank you
rajm
Community Member
Here is the solution I just used:
Switch#switch 2 renumber 1 (note this command is run in exec mode and not in global config mode)
WARNING: Changing the switch number may result in a configuration change for that switch. The interface configuration associated with the old switch number will remain as a provisioned configuration. New Switch Number will be effective after next reboot. Do you want to continue?[y/n]? [yes]:
Switch#
Switch#
Switch#show int status
Port Name Status Vlan Duplex Speed Type
Gi2/0/1 notconnect 1 auto auto 10/100/1000BaseTX
Gi2/0/2 notconnect 1 auto auto 10/100/1000BaseTX
Gi2/0/47 notconnect 1 auto auto 10/100/1000BaseTX
Gi2/0/48 notconnect 1 auto auto 10/100/1000BaseTX
Te2/1/1 notconnect 1 auto auto unknown
Te2/1/8 notconnect 1 auto auto unknown
Switch#
Switch#reload
System configuration has been modified. Save? [yes/no]: yes
Building configuration...
[OK]Reload command is being issued on Active unit, this will reload the whole stack
Proceed with reload? [confirm]<Press enter here>
*May 1 17:13:30.369: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
Chassis 2 reloading, reason - Reload command
May 1 17:13:39.799 FP0/0: %PMAN-5-EXITACTION: Process manager is exiting: reload fp action requested
May 1 17:13:41.178
Initializing Hardware...
System Bootstrap, Version 16.8.1r [FC4], RELEASE SOFTWARE (P)
Compiled Mon 03/19/2018 22:15:31.70 by rel
Current ROMMON image : Primary
Last reset cause : SoftwareReload
C9300-48P platform with 8388608 Kbytes of main memory
boot: attempting to boot from [flash:cat9k_iosxe.16.06.05.SPA.bin]
boot: reading file cat9k_iosxe.16.06.05.SPA.bin
Switch number is 1
Switch#term len 0
Gi1/0/1 notconnect 1 auto auto 10/100/1000BaseTX
Gi1/0/2 notconnect 1 auto auto 10/100/1000BaseTX
Gi1/0/47 notconnect 1 auto auto 10/100/1000BaseTX
Gi1/0/48 notconnect 1 auto auto 10/100/1000BaseTX
Te1/1/1 notconnect 1 auto auto unknown
Te1/1/8 notconnect 1 auto auto unknown
Switch#
I hope it helps!!!
