Removing a switch from a 4 switch 3750 stack
laichenkang
What is the behavior of the config if I were to remove the second switch from a 4 switch 3750 stack. Would the switch 3 reassign itself to 2? What if I want to move switch 4 (48 port) to switch 2 (24 port)?
This a permanent removal.
Jerry Ye
If you remove 2 from the stack, 3 will remain as 3 and 4 will remain as 4. Even if you put 4 into 2's position.
Please see the following documentation for more info:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_35_se/configuration/guide/swstack.html#wp1182077
HTH,
jerry
Unfortunate I'm still using 12.1
Thanks for the clarification. However, the 12.1 is behaving a little different from 12.2.
If you remove 2 and replace with the same model, the new switch will become 2. Please see the following link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.1_19_ea1/configuration/guide/swstack.html#wp1151629
You can also change the switch member number:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.1_19_ea1/configuration/guide/swstack.html#wp1112897
However, please back up your config or lab it before trying it.
HTH,
jerry
