Removing AAA configuration from a CIsco switch configuration
I have a switch configuration for a CIsco 2960S a text document that I would like to remove the AAA configuration from so it no longer calls any Radius switch and just uses the local login
Looks like I need to remove
  • aaa new model
  • aaa authentication login default group radius local
  • aaa authorization exec default group radius if-authenticated
  • Radius server "host" and "key" lines
  • aaa session-id common
  • line con 0
  • line vty 0 4
  • all password lines
Any amendment to this, or further things I should do?
This to be sure I can log into the switch without requiring radius to be up
Reza Sharifi
After removing the AAA config, make sure you have a local username and password configured so you can get back to the switch.
username abcvfvrvr privilege 15 password 7 ccvdvvdvdddv
under the vty line
login local.
Also, I recommend not saving the config after removing AAA configuration until you test and make sure you can get back to the switch with the local username and password before saving the config.
This way, if you can not get back to the switch, you can always reboot it and get back to it with the old config.
Hello
Just change the AAA to use local credentials:
aaa new-model
aaa authentication login default local
aaa authorization exec default local if-authenticated
Kind Regards
Paul
