Removing Crypto from 3560
davidhuynh5
After performing a write erase and delete vlan.dat on my 3560, the crypto keeps coming back into the configuration (see attachement). Does anyone know why it keeps coming back and how to permanently remove it? Thanks in advance.
Jerry Ye
Hi David,
Before you do a write mem, do no ip http secure-server in global configuration mode. This should remove the crypto certificates.
HTH,
jerry
davy.timmermans
Level 4
Level 4
you can try
crypto key zeroize rsa
