renumber switch number x to y
robertkwild
hi all,
can i renumber switch 2 to 2 on the master switch or can i only do this on switch 2, ie atm switch 2 says 1/1/1, i want to relabel it 2/1/1
thanks,
rob
balaji.bandi
if that is master switch if that looking your interface 1/1/1  - my best approach, Turn off the device, Turn on each device change the renumber and priority write the config each device same proceedure, then turn on MAster switch and secondary check with show switch.
BB
6 Replies 6
balaji.bandi
BB
so i can renumber switch 2 via the master ie switch 1?
robertkwild
sorry, im deleting this reply as it was in wrong thread
yes you can depends how many switches in stack ?
example :
https://community.cisco.com/t5/networking-documents/changing-a-switch-member-number-in-a-3850-stack/ta-p/3160671
BB
ive got 7 switches in stack, so lets say i can renumber all of them via the master one?
yes  yoiu can do, make sure you change the uplinks depends on number switch changed, suggest to do in maintenance window, since stack / member required to get new number effective.
BB
