Replace a Cisco 6800IA switch from an Instant Access client stacking.
Kmarkrousis
Could you please let me know the process in order to replace a failure Cisco 6800IA switch from an instant Access stacking?
Currently i have two Cisco 6800IA in stack mode and i have associated with the number FEX 120 to the parent switches, each 6800IA has an uplink to the parent switches. I need to replace the one of the two. Please let me know if the only that i need to do is to remove the failure and connect the new with the stack cables and the uplink to the parent switch and power it on ?
Thanks in advance.
0 Replies 0
