Replace a Switch
Jose Lopez
Level 3
Level 3
Hello everybody.
I have to replace a Switch with a fan fail and I would like to know more about the replacement process.
Are these the steps to follow?
  • Remove the damaged device and unclaim.
  • Add new device and claim.
  • Clone de new device.
Can I clone a new switch using the previously removed switch configuration?
Is the configuration still available?
Thank you.
You need to clone before removing the device from your network.
5 Replies 5
MerakiGnome
Meraki Community All-Star
Hi @Jose Lopez
Documented process here:
https://documentation.meraki.com/MS/Other_Topics/Switch_Cloning
Darren OConnor
https://www.linkedin.com/in/darrenoconnor
but, is the configuration still available after removing of network the damaged switch?
MerakiGnome
Hi @Jose Lopez , as stated by @Dylan_YYC , clone first then remove from Network.
You won’t lose any switch config.
Completed a zillion times. Works a charm.
Darren OConnor
So the steps are
1. Claim the New switch - which I got via the RMA Process and Add to the Network.
2. Clone the Bad Failing Switch to the New Switch
3. Remove the Bad Switch, and Unclaim it from Inventory
4. Mail the Bad Switch back
