Replacing 3524's and 3548's
dcmsupport
my network consists of the normal CORE (2 CAT6506), Distribution (Cat3550 12g, and Access Cat3524 and 3548) I will be upgrading the 3550's and 3500xl's. I have 3 sets of 4 of the 3500xl's "chained" together through the fiber ports going back to 2 separate 3550's. Each "set" is in a separate VLAN. The question I have is should I upgrade to 3750's or to 4948's and combine the access and distribution layers into one combined layer?
Thanks for any responses
Offlist contact is fine
Marc Westberg
mwestberg at deephavenfunds dot com
cpembleton
Level 4
Level 4
It is always better to follow a good hierarchical design. Makes it easier to grow and make changes. Although, each network is different.
Chad
Chad,
You are saying I should keep the original Core,Dist,and Access topology? If so what switch upgrade path would you recommend. I.E what maodel for the dist and access. I like the thought of 96Mb/s throughput(backplane) on the 4948 for the access layer, but what would you use for the distribution layer.
Thanks for your thoughts,
MArc
