Replacing 6807 VSS Standby Sup with RMA Sup
misaleh
After setting up the VSS configuration for the new sup2T and reloading it, will I need to reload the active switch as well? I don't want to have to reload the active switch since we cant afford to have any downtime atm.
Also, is the below configuration all I need to do on the new standby supp?
Router# mode sso
Router(config)# switch virtual domain #
Router(config-vs-domain)# switch 2
Router(config)# interface port-channel #
Router(config-if)# switch virtual link 2
Router(config)# interface range tengigabitethernet <intid>
Router(config-if)# channel-group 20 mode on
Router# switch convert mode virtual
balaji.bandi
is this Dual sup in the same chassis?
if you replaced standby Sup, you do not need to reload.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-virtual-switching-system-1440/109334-replace-vss-sup-proc-v1.html
BB
Single sup in each chassis
if everything ok version is same as Live, you should be good. check the document which help you.
BB
