Replacing Dead Switch in Switch Stack
I have a switch that is toast and needs to be replaced. It is module 4 out of 6. When I run a show switch I can only see 5 active switches and the one for number 4 says "provisioned"
My question is if I slide the broken unit out and replace with an identical model, do I need to do any additional switch configs or will the stack recognize the replacement as blade 4 and install the config?
1-Upgrade the new switch to whatever version is running on the stack
2-Make sure the new switch has the same license level as the stack
3-Provision the switch and configure it with the same priority as the bad one
4-Unplug the stack cable and power cord from the bad switch
5-Add the new switch to the stack, connect the stack cables, and finally turn on the switch.
Ensure you do this in a maintenance window, just in case.
6 Replies 6
Sorry, I forgot to include that it is a C9300-48UXM being replaced.
Beautiful. This was very helpful. Thank you Reza!
Coming back to update that your steps worked flawlessly and I was able to swap the device in a live environment. The stack didn't go down and the replacement switch was accepted / kept config.
Thank you again!
Thanks for the update
I am glad to know the steps worked as expected.
Good luck!
bhowvghq
Community Member
I was in somewhat same situation and luckily this solution worked for me as well. Now I have no such problem and I can easily access my site. Otherwise it was headache.
