01-19-2016 11:32 AM - edited 03-08-2019 03:27 AM
I have to replace standalone sup 720 in c6509 chassis. This sup act as a stanby engine in VSS configuration.
I am going to follow next steps:
1. Disconnect cables from standby sup
2. Remove supervisor (hot swap)
3. Remove CompactFlash (bootdisk sp) from old one install into the new one
4. Insert the new sup into the chassis
5. Copy config from bootdisk to startup-config
6. Power down
7. Connect all cables and power on.
Is it safety to replace the supervisor without powering down the entire chassis? Any suggestions/corrections to my plan.
Thanks in advance!
01-19-2016 11:46 AM
I'm not sure, does this help?
Replace Supervisor Module in Cisco Catalyst 6500 Virtual Switching System
01-19-2016 11:53 AM
Philip,
Thanks for your promt reply. I have seen this guide but there is no answere on my question:
"Is it safety to replace the supervisor without powering down the entire chassis? "
I use only one supervisor per chassis.
01-19-2016 12:04 PM
This sounds promising:
