Replacing Supervisor Modules (SUP3) on a Cisco 7000 Nexus Device
cesarausan
This is my first time using the Cisco community forums.
I have reviewed the following Cisco white paper:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/high_availability/configuration/guide/b_Cisco_Nexus_7000_Series_NX-OS_High_Availability_and_Redundancy_Guide/b_Cisco_Nexus_7000_Series_NX-OS_High_Availability_and_Redundancy_Guide_cha...
But I can't find answer to the following question:
When the standby sup is replaced. will the new standby sup receive the same NXOS revision as the active sup?
Reza Sharifi
According to the link you posted, the new standby sup will receive the same version as the active sup.
  Command or Action Purpose
Step 1 switch # system switchover
Initiates a manual switchover to the standby supervisor.
Note
Wait until the switchover completes and the standby supervisor becomes active.
Step 2 switch# out-of-service slot-number
Powers down the supervisor module you are replacing.
Step 3 Remove the supervisor and insert the replacement.
The new supervisor will automatically sync up the image and configuration from the currently active supervisor.
Reza Sharifi
Note
