Replacing WS-SUP720-3B with a VS-S2T-10G
kasmall
I have a remote pair of production 6509-E switches I need to replace the Supervisors in to support WS-X6716-10T-3C line cards.
Is there any easy way to replace a WS-SUP720-3B with a VS-S2T-10G, preserving the existing swtich/port configurations quickly?
Kathie
Reza Sharifi
You can most likely preserve most of the config from the existing sup720-3B and copy and paste it into the new sup-2T, but there are certain sections like the QOS config that you have to change manually, as these 2 sups have different QOS architectures.
