Reservation Authorization Code does not match Reservation Request Code
anthonyg2879
Community Member
Hello Team,
Is anyone able to provide an area of direction to get the above error resolved?
Error:
Reservation install file failed: The Reservation Authorization Code does not match the Reservation Request Code
Everything looks correct on the Smart Software Licensing portal on Cisco site.
This is a 4 switch stack ... I was able to get 3/4 licenses registered. This is the only one in the stack providing this error.
I did them one by one.
I re downloaded the Reservation Authorization Code from Cisco portal and still same issue.
Is there anything to view in the Authorization Code via text editor to confirm if the Request Code matches?
StackSwitch#show lic res
Overall status:
Active: PID:C9300-48U,SN:
Status: RESERVATION IN PROGRESS on Dec 20 14:41:25 2022 UTC
Request code:
Standby: PID:C9300-48U,SN:
Status: SPECIFIC INSTALLED on Dec 20 15:40:40 2022 UTC
Last Confirmation code:
Member: PID:C9300-48U,SN:
Status: SPECIFIC INSTALLED on Dec 20 15:40:23 2022 UTC
Status: SPECIFIC INSTALLED on Dec 20 15:39:58 2022 UTC
HA UDI List:
Active:PID:C9300-48U,SN: One i am not able to get registered
Standby:PID:C9300-48U,SN:REGISTERED
Member:PID:C9300-48U,SN:REGISTERED
Mark Elsen
 - Review this document : https://www.cisco.com/c/en/us/support/docs/licensing/common-licensing-issues/how-to/lic217542-how-to-install-the-authorization-code-on.html
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Thank You for the direction. Yes, that is the process i followed. I was able to activate the three other switches in the stack successfully but just that one i am getting that error.
I am trying to troubleshoot on why i am being told that error.
Is there anything deeper i can look into to see where the root of the error might be?
 - Not that I know off  , in the end you may try to factory reset and then try to join it to the stack again , taking into account correct procedures such as configuring another stack master first (e.g.)
 M.
