Reserved Static IP Using SDM Software
hoadotnguyen
I am using SDM 2.4 and I want to reserved static on client PC. How do I do this in SDM? Thanks,
derrickc
You can probably create DHCP pools from within SDM, but not for static bindings. I've not used SDM in a while, but I use ASDM to manage my firewalls. Within ASDM, I can create a DHCP pool, but there is no place to configure static bindings.
You will have to do it from the command line as I posted in your previous request.
How do I create HCDP pools from within SDM? Thanks,
