Reset Catalyst 9300 to WebUI
Is it possible to factory reset the switch back to day 0 config if you don't know the IP address?  Something went wrong during the WebUI process and I am now unable to access the switch.  The default IP address is not reachable through the web or console.  What can I do if I don't know the IP?
Reza Sharifi
If you have not saved the config, reloading the switch should take you back to when you started.
