reset port settings
majdalani
lets say i have some configurations on a port and i want to remove all these configurations, i dont wish to use the No command before each line .
how can i remove for example 6 configurations ina single command line ? that is to reset the port to a non configured port
n.nandrekar
Level 4
Level 4
hi!
You can use the "default interface giX/X " command in the config mode. It will reset the interface to its defaults.
Niranjan.
(pls rate helpful posts)
n.nandrekar
Level 4
Level 4
hi!
Niranjan.
Thanks Niranjan.
